1998 Mercury Marquis O/D Off Light
1998 MERCURY MARQUIS
DRODLLC
Electrical problem
1998 Mercury Marquis V8 Two Wheel Drive Automatic
O/D Off light is flashing when hard shift from 2-3 and 3-4. Transmission appears to be performing fine except holds 2-3 and 3-4 shift points longer than normal.
Mar 21, 2010 at 4:03 AM
2CARPRO JACK
  • 11,533 POSTS
The flashing light is the PCM's (Computer) way of telling you it sees a problem in the trans.You need to have the PCM scanned for trans codes to see what the problem is.May just be a bad sensor or solenoid, but it should have stored a code if the light is flashing
Mar 22, 2010 at 1:09 AM
