1998 Mercury Marquis front rotors
110,000 MILES • V8 • 2WD • AUTOMATIC
MAQCOBRA
how do i remove and replace the front rotors I have already removed the caliper and the pads what is the next step the rotor is not coming off please help thank You!
Jul 20, 2008 at 1:11 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:2aa38c2788="maqcobra"]Brakes problem
1998 Mercury Marquis V8 Two Wheel Drive Automatic 110000 miles
how do i remove and replace the front rotors I have already removed the caliper and the pads what is the next step the rotor is not coming off please help thank You![/quote:2aa38c2788]
Look around the face of the Rotor for a couple Philips Scew Heads. If there use EXACT SIZE to remove just make spray them good with WD40 or similar and let set for about 30 minutes.
If doesn't have the screws look for spring locks on 2 of the studs.
If doesn't have you will have to spray around center hole and studs then beat inbetween each stud to break rust. May take some beating also beat on the top side of rotor.
Jul 20, 2008 at 1:58 PM
