1998 Mercury Marquis diagnostic code P0430
239,000 MILES • V8 • 2WD • AUTOMATIC
ERIC M
code P0430 keeps engine light on all the time. have been told by others it is a bad ox sensor and won't do any harm. Is this true? and what can be done
Feb 17, 2009 at 10:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
Indicates a faulty oxygen sensor on bank 2 of exhaust. Failing to replace it will result in much lower fuel mileage and eventually it will ruin the catalytic converter, a very expensive component.. I suggest replacing the sensor as it is very simple and cheap.
Thanks for using 2CarPros.com!
Feb 17, 2009 at 11:26 AM
