1998 Mercury Marquis auto door locks
76,000 MILES • V8 • 2WD • AUTOMATIC
TOPYR
My door locks do not lock all the time when the transmission is put in gear. Second, when I use the manual door lock switch on the drivers side only, it will not work if the drivers door is opened.
Jun 14, 2008 at 3:57 AM
MERLIN2021
  • 17,250 POSTS
Seems by the symtoms, you may have a broken wire were they pass thru the door, and into the car. Inside the rubber boot...they flex at this point, and can crack.
Jun 14, 2008 at 6:19 AM
