1998 Mercury Marquis a/c compressor
222,000 MILES • V8 • 2WD • AUTOMATIC
SAMSCLUB
Mechanic tells me the a/c compressor has burned out. Is there an easy way to allow the pulley on the compressor to continue to turn with the drive belt. I do not need the a/c to work, but cannot have the compressor lock up and keep the drive belt from turning and keep the car from running.
Jun 11, 2008 at 3:44 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:0ecfa511a6="samsclub"]Air Conditioning problem
1998 Mercury Marquis V8 Two Wheel Drive Automatic 222000 miles
Mechanic tells me the a/c compressor has burned out. Is there an easy way to allow the pulley on the compressor to continue to turn with the drive belt. I do not need the a/c to work, but cannot have the compressor lock up and keep the drive belt from turning and keep the car from running.[/quote:0ecfa511a6]
As long as the A/C Clutch is not engaged you should be fine. If your are concerned about it there is an aftermarket pulley to replace the A/C Compressor.
Jun 14, 2008 at 9:19 AM
