1997 Mercury Marquis possible brake pad rattle?????????
142,000 MILES • V8 • 2WD • AUTOMATIC
STEVE1973
Horrible rattle when going over bumps in the road. Sounds as if the pads are loose. Replaced the front pads and rotors w/ rattle clips. This worked for about a week, it came back. Someone suggested possible bad caliper piston. Bought loaded calipers and replaced. Didn't change a thing. Rattle is not present when brakes are in use, which is why I thought it was loose pads. Could this be a possible front end problem? Also don't know if this is a related problem, but when coming to a stop the brakes seem to pulsate the slower the car travels. Thought maybe bad rotor, but it only seems pulsate at low speeds? Any help would be great. This rattle is bugging the hell out of me.
Jun 24, 2009 at 3:27 AM
MERLIN2021
  • 17,250 POSTS
If it not the anti-rattle clip on the inboard pad, it could be the rubber guide pin boots are worn...these are the rubber mounts the pins go into. also check the steering knuckle for wear where the pds contact it, especially inboard.
Jun 25, 2009 at 6:03 AM
