1997 Mercury Marquis ignition control module
GLX1963
Electrical problem
1997 Mercury Marquis V8 Two Wheel Drive Automatic
where is the ignition control module located on my 1997 mercury grand marquis w/4.6L engine. It's suppose to be located on fenderwall but cannot find. Please help need to have it tested , car won't start.
May 3, 2009 at 9:41 AM
BMRFIXIT
  • 19,053 POSTS
You have two coils one on each side of the engine
PCM pulse them both
so need for an ignition module PCM does it all
do self diagnose check (KOEO test )
check fuses
check and suspect crank sensor
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
May 3, 2009 at 9:59 AM
