All of a sudden the horn is not working. I have checked the fuses under the dash and they all are okay. I don't know where to go from here.
Sep 7, 2010 at 9:28 AM
SATURNTECH9
✓Experienced Mechanic
Go to the horn connector make sure the black wire to the horn has a good ground.Then make sure the dark blue wire to the horn has battery voltage when you press the horn button.If all that's good then you have a bad horn.
Sep 7, 2010 at 9:39 AM
