1997 Mercury Marquis flood got me i think?
1997 MERCURY MARQUIS
70,000 MILES • V8 • FWD • AUTOMATIC
EWALLACE07
drove through some unavoidable standing water in a recent flood. car was not submerged nor did it stall. but there is a whistling noise I cant get rid of I sprayed belt frip but did not work any ideas
Jul 31, 2010 at 9:35 PM
  • 31,937 POSTS
Hi there,
A whistle is more (excuse the pun) in tune with a vacuum leak, i would be checking this first.
Mark (mhpautos)
Jul 31, 2010 at 10:50 PM
EWALLACE07
it becomes louder and more frequent as I accelerate, and I know whatever it maybe it is directly related to driving through standing rain water cold that be the vaccum leak?
Jul 31, 2010 at 10:57 PM
  • 31,937 POSTS
With a vacuum leak there will normally be some idle concerns, higher idle or a rough idle, have you checked all the belts for tension and condition? belt grip is not a great idea as the muck is so stick, it will pick up road grit and damage belts, check for any loose or cracked vacuum hoses and check the belts, you can also remove the belts and run the engine, if the noise is gone, it will be belt related.
mark (mhpautos)
Jul 31, 2010 at 11:02 PM
