The Turn Signal Flasher output is provided by the Lighting Control Module, which is located behind the LH side of the instrument panel. There are no separate relays for Turn Signal Flasher output aside from the LCM.
Thanks for using 2CarPros.com!
Jan 3, 2020 at 7:16 AM
(Merged)
