1997 Mercury Marquis Compressor
135,000 MILES • V8 • 2WD • AUTOMATIC
MATHESO7
I am having problems with my A/C Compressor. I recharged the system with R-134a. The compressor finally kicked in, but only works for about 5 seconds then cuts off. About 20 seconds later it starts again, then cuts off. I do not hear any squealing from the belts, and the compressor sounds ok when turning. Do I have a bad clutch, or is there a bad sensor somewhere. Also, it blows very hot air when on Max A/C. Thanks
May 25, 2010 at 7:14 AM
DOCFIXIT
  • 18,828 POSTS
Was system vaccumed down before charging?
May 26, 2010 at 6:32 AM
MATHESO7
I did not vacuum the system, just added about 11oz. to the system.
May 26, 2010 at 7:47 AM
DOCFIXIT
  • 18,828 POSTS
What are low and high side pressures?
May 27, 2010 at 4:57 AM
