Is the idle of engine to low?Maybe its just that you need the idle to be a little higher.I doubt your oxigen sensor would do that. If you wanna reset computer yourself do this.>>Disconnect one cable from battery for about 15-20 minutes then connect back again. Reset done. Good luck
SPONSORED LINKS
Tuesday, July 29th, 2008 AT 1:03 AM
