1996 Mercury Marquis Replace front psgr window regulator on
1996 MERCURY MARQUIS
NICKSTER
Electrical problem
How do you replace the front passenger window regulator on a 1996 Mercury Marquis? After I drill out the glass rivets, what size do I replace the rivets with? 1 & 1/2 inch hex head bolts and washers and nylon insert locking nuts? How do put back the sheet plastic water barrier? Glue? What kind of glue?
Mar 20, 2009 at 7:15 AM
MERLIN2021
  • 17,250 POSTS
Ford actually has a large rivet gun to replace these, and I use tape to rehang the barrier.
Mar 20, 2009 at 7:25 AM
NICKSTER
[quote:8224378127="merlin2021"]Ford actually has a large rivet gun to replace these, and I use tape to rehang the barrier.[/quote:8224378127]
Just regular scotch tape or duct tape?
Mar 20, 2009 at 7:32 AM
MERLIN2021
  • 17,250 POSTS
Scotch tends to loose its grip, use the duct if you have it.
Mar 20, 2009 at 8:56 AM
NICKSTER
[quote:1ff9a5aaad="merlin2021"]Scotch tends to loose its grip, use the duct if you have it.[/quote:1ff9a5aaad]
If not duct, what tape do you recommend?
Mar 20, 2009 at 9:18 AM
