1996 Mercury Marquis fuel regulator
PAM AVANT
Engine Performance problem
1996 Mercury Marquis V8
How do you install a new fuel injector pressure regulator on a 1996 grand marquis
Jun 26, 2008 at 8:47 AM
MERLIN2021
  • 17,250 POSTS
Relieve the pressure in the rail, unplug the vacuum line, remove the mounting screws, remove..if you need to lube the new O rings, use a small bit of oil..
Jun 26, 2008 at 8:56 AM
