1996 Mercury Marquis Door locks
95,000 MILES • V8 • 2WD • AUTOMATIC
WIFESCAR
The Automatic door locks quit working yesterday,
The fuses all check good, the power seats and windows still work(same fuse) , the remote keyless entry does not work , the keyless entry on the door dose not work or even light up,
The power seats and the door locks are on the same high current fuse/relay according to the owners manual, since the power seats still work, I don't think its a fuse on the fuse panel interior or the high current fuse panel in the engine compartment because only the door locks don't work . and trunk release .
stumped for now
thanks
Dec 5, 2007 at 2:51 AM
2CARPRO JACK
  • 11,533 POSTS
Looks like all of those things go through the drivers door module.Located in the l/f door. Lighting for key pad, door locks and trunk release all go through it. Check for loose/corroded connectors, broken wires in the door
Dec 5, 2007 at 11:36 PM
WIFESCAR
I disconnected the battery, let the system reset and it all works, for now
Dec 6, 2007 at 10:44 AM
2CARPRO JACK
  • 11,533 POSTS
hopefully it was just a hiccup !
Dec 6, 2007 at 11:19 PM
