1996 Mercury Marquis air intake
215,000 MILES • V8 • 2WD • AUTOMATIC
TOTHH
need to replace air intake has a crack on front coolant crossover are there any special tools needed to do this never done it before but have to do it myself as do not have the money for an auto shop ...
Mar 7, 2008 at 10:48 AM
MASTERTECHTIM
  • 4,750 POSTS
no special tools except for a fuel line disconnect(you can purchase tool at parts store for a couple bucks) pretty straight forward job.
Mar 7, 2008 at 10:50 AM
TOTHH
[quote="mastertechtim"]no special tools except for a fuel line disconnect(you can purchase tool at parts store for a couple bucks) pretty straight forward job.[/quot
thank you very much I am buying a used on from wreckers and not sure so thank you
Mar 7, 2008 at 10:53 AM
MASTERTECHTIM
  • 4,750 POSTS
be careful when purchasing used. most of the intakes that are plastic at the thermostat housing break. ford has updated the intake and made the front part aluminum.
Mar 7, 2008 at 10:58 AM
TOTHH
[quote:b03dc5abed="mastertechtim"]be careful when purchasing used. most of the intakes that are plastic at the thermostat housing break. ford has updated the intake and made the front part aluminum.[/quote:b03dc5abed]
i realized that the one i am getting is an updated one i am more worried about messing it up than anything but i am usually pretty good at this always succeded before just the injectors scare me
Mar 7, 2008 at 11:00 AM
MASTERTECHTIM
  • 4,750 POSTS
as far as intake replacements go this has got to be the one i would be least scared of. there is really nothing you can do wrong unless you are an absolute animal. really you will be surprised how fast and easy you get this done. good luck
Mar 7, 2008 at 11:13 AM
TOTHH
[quote:450ae8229f="mastertechtim"]as far as intake replacements go this has got to be the one i would be least scared of. there is really nothing you can do wrong unless you are an absolute animal. really you will be surprised how fast and easy you get this done. good luck[/quote:450ae8229f]
how long should it take
and thanks for your help
Mar 7, 2008 at 11:51 AM
MASTERTECHTIM
  • 4,750 POSTS
a few hours
Mar 7, 2008 at 12:00 PM
