Ac drain tube
1996 MERCURY MARQUIS
80,000 MILES • V8 • 2WD • AUTOMATIC
GHALL4232
Where is the AC drain tube located on a 19196 Mercury Marquis V8 and how do I unclog it
Feb 1, 2009 at 5:29 AM
  • 55,186 POSTS
The ac drain tube is located on the passengers side near the firewall under the car. You will need to raise the car safety.
Here is a guide.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Once you find the tube used compressed air or a wire to poke up into the drain this will clear the obstruction and make the water flow again.
Cheers, Ken
Aug 30, 2017 at 12:57 PM
