1995 Mercury Marquis fuel filter
F.A.PIPPETT
1995 Mercury Marquis V8 94745 miles
Where is the fuel fliter found on my car?
Jun 4, 2010 at 8:54 AM
  • 75,988 POSTS
Fuel and Vapor Line Routing
https://images.2carpros.com/forum/automotive_pictures/12900_fuel_filter_3.gif
REMOVAL With engine OFF, relieve the fuel system pressure, refer to the Fuel Pressure Release Procedure. See: Fuel Pressure Release Raise the vehicle on a hoist. Remove the push connect fittings from both ends of the filter. Remove the fuel filter and retainer from the metal bracket by removing the two retaining bolts. Remove the filter from the retainer. Note the direction of the flow arrow. Remove the rubber insulator rings from the filter. INSTALLATION Install the rubber insulator rings on the new filter. If the filter moves freely in the retainer, replace the insulator rings. Place the filter in the retainer with the arrow pointing out of the open end of the retainer. Install the fuel filter retainer on the metal bracket and tighten the bolts to 9-12 Nm (80-106 lb in) . Install the push connect fittings onto the filter ends. Cycle ignition switch from OFF to RUN position several times, without starting engine. Check for fuel leaks. Lower vehicle.
Jun 4, 2010 at 9:08 AM
