Engine problem
1994 Mercury Marquis V8 Wheel Drive Type unknown Automatic 158.00 miles
My question was my oil light turns on when I am using the car, Ill start the car & there's no oil light for a while I use about 25 minutes then it turns on but does turn off when I step on the was but when I slow down and stop then it turns right back again, I step on the gas then off again. the car has oil I check every day. do I need to change the oil pump, because i switch the oil sensor but didn;t make a diffrence. what do you recomened is the problem new oil pump or is there other options?
Jan 17, 2008 at 1:17 AM
