Last night I went to start my car and heard a snap inside the steering column. I could not start the car but all of the dashboard indicators were lit up. I switched out the ignition cylinder & was able to start the car but was unable to turn it off. When I turn the ignition off it goes where it should but the car continues to run. Any suggestions? Thank you in advance.
Thank you for your feedback. I did change out the switch. Unfortunately, I still have the same problem. When I turn the key to the off position, the car does not turn off. What am I missing? Any other suggestions?
SPONSORED LINKS
Tuesday, February 19th, 2008 AT 10:45 AM
