1993 Mercury Marquis oil filter housing
1993 MERCURY MARQUIS
RANGERJ
  • 17 POSTS
Engine Mechanical problem
1993 Mercury Marquis V8 Two Wheel Drive Automatic
Does a 1993 Mercury Marquis have an oil filter housing gasket? This one is leaking around the filter housing I am not sure how to stop it. need advice also will a carbon cleaner additive clean out the egr enough to make the check engine light go out?
Jan 20, 2009 at 7:24 AM
  • 110,244 POSTS
Hi:
replace the oil filter to see if that fixes the oil leak. As far as the additive, is this something you add to the oil or fuel? If so, it won't help the EGR.
Let me know what you find.
Feb 18, 2009 at 12:20 PM
RANGERJ
  • 17 POSTS
[quote:ceea86f396="Jacobandnickolas"]Hi:
Joe[/quote:ceea86f396]
Thanks for your reply. I had to have the oil filter housing gasket replaced. Also will an intake vacuum line cleaner like seafoam or similar product clear the egr passage?
Feb 25, 2009 at 1:38 AM
  • 110,244 POSTS
Feb 25, 2009 at 1:40 AM
