1992 Mercury Marquis stuck gear shifter
150,000 MILES • V8 • 2WD • AUTOMATIC
MFOY01
what controls the gear shifter from moving out of park is it the neutral safety switch had a problem with the headlight switch the door locks stopped and started working along with the rear window defroster could that switch be tied into the neutral safety switch
Nov 29, 2009 at 10:19 PM
BMRFIXIT
  • 19,053 POSTS
Check fuses
step on the brakes check if have brake lights if not check brake light switch and its power supply
Nov 29, 2009 at 10:21 PM
