1992 Mercury Marquis Slipping out of OD
222,960 MILES • V8 • 2WD • AUTOMATIC
OPEONGO66
My transmission slips out of OD or refuses to down shift to passing gear when accelerating to highway speeds. Also much shuddering at the same time. Lower gears are fine. Same problem in all temps. Better out of OD position but not much. It seems like the Torque convertor is slipping. Also there is a vibration fromthe right side of the vehicle at highway speeds. Don't know if it is related. Cruise does no function properly either. ANy help would be appreciated.
Oct 20, 2008 at 2:01 PM
302ERNIE
  • 9 POSTS
THERE IS A PLASTIC GROUMENT OR CLIP THAT GOES ON THE THROTTLE LINKAGE ON THE THROTTLE BODY IT GOES TO THE TRANS LINKAGE IT IS CALLED TRANS DETENT THEY CRACK AND FALL OUT COSTS ABOUT ADOLLER IT ALSO CONTROLS CRUISE
Jan 30, 2009 at 6:47 AM
