the fuse on my fuel pump keeps blowing out when the car is starting this is a 1992 grand marguis has ran very well i would like to keep it.
Dec 11, 2007 at 9:02 AM
✓Experienced Mechanic
Do you have a repair manual? if not see below-If so find the fuel pump relay in relay center on left side of engine compartment and remove it-now put a new fuse On did it blow?
Dec 11, 2007 at 9:41 AM
CLUDEE
MEMBER
[quote="cludee"]Other Category problem
1992 Mercury Marquis V8 Two Wheel Drive Automatic 16200miles
the fuse on my fuel pump keeps blowing out when the car is starting this is a 1992 grand marguis has ran very well i would like to keep it The engines 4.6liter is quiet. Can you hepl me with this.
Dec 11, 2007 at 11:35 AM
This problem is not a very simple thing to fix over the internet. You have a short somewhere within the fuel pump circuit-check the fuel pump relay/inertia cut off switch,fuel pump and wiring.
If you are a DIY with no electrical experience-you need to bring it in. You might end up making things worst then it is.
