1991 Mercury Marquis shimmy front left
70,000 MILES • V8 • 2WD • AUTOMATIC
STEVE66SOUTH
Had a slight shimmy on front left ,since I needed brakes, I replaced the pads and rotors were smooth so no problem there. I also put two new shocks on since I was down there.lubed everything up,put it all back together ,but I still have the shimmy up and down when i apply the brakes. at low speeds not too bad,but ai high speeds when i apply the brakes its real bad
Apr 18, 2008 at 11:40 PM
SERVICE WRITER
  • 9,123 POSTS
You should have replaced the rotors, they are warping under heat and stress.
Apr 19, 2008 at 12:28 AM
