1990 Mercury Marquis map sensor
1990 MERCURY MARQUIS
145,000 MILES • V8 • 2WD • AUTOMATIC
MR. GRANT
will a defective MAP sensor cause the car, to hard to start to almost no start when cold, and not restarting after its been running for a while? This all started, one morning, I fired up the car, it idled fast, then idle down, then it would fast idle while driving. Changed the fuel filter and the idle problem seemed to go away. next thing I know, it wouldnt start right away, took a couple times. Now having almost no luck at all. ran a code test and, 44 and 77 or 74 ( map and thermal maxor ?). please help, thanks
Dec 25, 2007 at 4:33 AM
BMRFIXIT
  • 19,053 POSTS
[quote:f7da8a1458="Mr. Grant"]Other Category problem
1990 Mercury Marquis V8 Two Wheel Drive Automatic 145000 miles
will a defective MAP sensor cause the car, to hard to start to almost no start when cold, and not restarting after its been running for a while? This all started, one morning, I fired up the car, it idled fast, then idle down, then it would fast idle while driving. Changed the fuel filter and the idle problem seemed to go away. next thing I know, it wouldnt start right away, took a couple times. Now having almost no luck at all. ran a code test and, 44 and 77 or 74 ( map and thermal maxor ?). please help, thanks[/quote:f7da8a1458]
you should start by the map sensor and its vacuum source and vacuum line
Dec 27, 2007 at 9:18 AM
