The heat/defrost does not work on car. I flushed heater core out and it flows well. The air blows out of heater box with heat turned on. The door operates well off cable from controls.I have been unable to find the heater control valve. Could you tell me where it is located and if this might be the problem?
Thank You
Thank You
Jan 13, 2008 at 8:44 AM
