1987 Mercury Marquis fuel pump
TRSHERWOOD
Engine Performance problem
1987 Mercury Marquis V8 Two Wheel Drive Automatic 140k miles
My son has a 87 marquis. It turns over, but will not start. It has good spark and will fire if we give it a light shot of starting fluid. Would the fuel pump be the first item to look at? Is it mechanical or electrical? If so where is it located? Thank you in advance.
Nov 26, 2009 at 3:23 PM
  • 110,248 POSTS
THis is going back awhile. I believe you have a carburator and not fuel injection. If this correct, you will have a mechanical pump. It is located on the driver's side of the engine near the oil filter. Here is a picture:
https://images.2carpros.com/forum/automotive_pictures/249084_pump_4.jpg
To check your pump, you need to do a volume test. The pump should produce 1 pint of fuel in 20 seconds. You may want to check it before replacing it. Here is a picture of the pump:
https://images.2carpros.com/forum/automotive_pictures/249084_pumpp_1.jpg
If your vehicle is fuel injected, let me know. It will have a completely different set up. Let me know. Joe
Nov 26, 2009 at 4:26 PM
TRSHERWOOD
I'm certain it is fuel injected. I have attached a photo for confirmation. My concern is that the fuel pump is in the tank. My folks had a t-bird from around the same time and I thought the pump was in the tank on that model. Don't know if Ford/Lincoln was doing that on a lot of models at the time.
https://images.2carpros.com/forum/automotive_pictures/440294_100_1713_1.jpg
Nov 27, 2009 at 2:56 AM
  • 110,248 POSTS
You are correct. It is fuel injected and I hate to say it but the fuel pump is in the tank. It is electric. I would recommend checking the fuel pump pressure?
It's an electric fuel pump. Keep in mind, there could be a problem with the fuel pump relay, fuel filter... Here is a "How To" for checking the pump. You will need a pressure gauge. Most parts stores will lend or rent them. As far as the process, it is easy to check. Please pay attention to fuel pressure drop off. THat is when you shut the key. Note how quickly the pressure drops.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find and we'll move in from there.
Nov 27, 2009 at 9:21 AM
