1981 Mercury Marquis No break lights
80,000 MILES • V8 • 2WD • AUTOMATIC
ASHMUR
I've checked all the fuses, they're okay, but I still don't have any break lights. The bulbs are good and the hazards and signal lights still work. The tail lights come on when I turn on the lights. What sould I look for to get the break lights to work?
Feb 1, 2008 at 8:48 AM
VOLTS
  • 16 POSTS
Hi
Check for bad or broken connections on the Brake light Switch located under the dash and mounted too the Brake Pedal Assembly, it could also be a bad Brake Light Switch as well.
Jan 4, 2009 at 3:41 AM
