1986 Merc Lynx Alternator replacement
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Ask the mechanic what test findings justify each replacement. The discussion provides no evidence that this solenoid failed or that the two parts require routine replacement together.
Guidance references and applicability
Source: This question and its visible discussion. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis.
Discussion summary
The owner of a 1986 Mercury Lynx asked whether replacing the alternator also required replacing the nearby starter solenoid. The owner said a mechanic routinely recommended replacing both.
Reported outcome: No solenoid diagnosis or completed repair was reported.
The nearby location and the mechanic's recommendation do not establish a fault. The discussion does not provide a vehicle-specific replacement procedure.
