1986 Merc Lynx Alternator replacement
OMNI1DA
When replacing the alternator on 1986 Merc Lynx, do you need to replace solenoid at the same time?
Jan 5, 2006 at 10:24 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Ask the mechanic what test findings justify each replacement. The discussion provides no evidence that this solenoid failed or that the two parts require routine replacement together.
Guidance references and applicability
Source: This question and its visible discussion. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis.
Read the replies · Discussion summary and reported outcome
SMOKINFLOYD4.3
  • 56 POSTS
no, the solenoid is for starting
Jan 5, 2006 at 10:25 AM
OMNI1DA
Thanx smokinfloyd. I was told by a mechanic that you always needed to replace the solenoid-by the battery not the firewall everytime I replaced the alternator.
Jan 5, 2006 at 10:34 AM
SMOKINFLOYD4.3
  • 56 POSTS
well its not neccesary, even though the solenoid is only like 10 bucks
Jan 5, 2006 at 10:49 AM
Discussion summary
The owner of a 1986 Mercury Lynx asked whether replacing the alternator also required replacing the nearby starter solenoid. The owner said a mechanic routinely recommended replacing both.
Reported outcome: No solenoid diagnosis or completed repair was reported.
The nearby location and the mechanic's recommendation do not establish a fault. The discussion does not provide a vehicle-specific replacement procedure.
Read the original discussion
