i have a 1985 mercury cougar 302 v-8 and we have replaced the water pump and the thermostat, why else could it still be over heating?
Feb 26, 2007 at 6:50 AM
Verify the cooling fan operates. Check the radiator for plugging by comparing temperature from the hot top toward the cooler bottom. If it has a clutch fan, compare blade spin resistance when cold versus after warm-up.
The owner of a 1985 Mercury Cougar 302 V-8 reports continued overheating after replacing the water pump and thermostat. Experts recommend confirming the fan works, checking for a plugged radiator by temperature from top to bottom, and testing clutch-fan drag cold versus hot.
