1995 Mercury Cougar No Start
NEEDHAM
i have a95 mercury cougar; 4.6 liter engine .i have changed the fuel pump and the fuel pressure regulator and it still wont start, but it is getting fuel to the fuel rail. what else could be wrong?
Sep 15, 2007 at 7:40 AM
  • 75,988 POSTS
Could be an ignition system problem-remove a plugwire or so-ground it to the engine while being crank over look for a spark-do you have spark? If not check the distributor pick-up or a crankshaft position sensor. What might be happening here is that the computer might not be getting a crank signal to activate the injector/s. In other words the computer don't know whether the engine is turning or what to give it fuel.
Good Luck
Sep 22, 2007 at 11:02 AM
MY68MONTERAY
  • 17 POSTS
i had a similar problem with my 91 cougar and it turned out to be a shorted out wire just 2-3 inches from the cylinoid. use a volt meter to check continuity of all cylinoid wires. (expecialy if you have a green wire that splits in to 2 or more) this also causes the altinator to not charge the battery
Nov 22, 2008 at 12:27 PM
Suggested Repair
Check for spark while cranking. If there is no spark, test the distributor pickup and crankshaft position sensor, since the computer may not be receiving a crank signal to fire the injectors. Also check starter solenoid wiring continuity, especially a green wire that splits.
Conversation Summary
The owner of a 1995 Mercury Cougar 4.6 says it will not start after replacing the fuel pump and fuel pressure regulator, although fuel reaches the rail. An expert advises checking for spark and, if none is present, the distributor pickup or crankshaft position sensor. Another owner reported a similar no-start caused by a shorted wire near the starter solenoid.
