2002 Mercury Cougar Rotor and Brakes
50,000 MILES • 6 CYL • FWD • AUTOMATIC
MERCURYCOUGARBK
Hi, This would be my first time trying to replace both rotor and brakes on my 2002 mercury cougar, I had watched your video online and was very helpful but do I need to drain the calipers fliud in order to take the brake pads and rotor off?
thanks
Brian
Jun 18, 2008 at 9:09 AM
DOCFIXIT
  • 18,828 POSTS
Get hold of a 6" C clamp any hadware store. Remove master cylinder reservoir cover if it is full you will need to get some out turkey baster works.
With caliper removed place C clamp inside piston and back of caliper screw it and piston will retract fluid will go to the master. That way no air no need to bleed.
Good luck
Jun 18, 2008 at 9:55 AM
