2002 Mercury Cougar quit on the road won't start
2002 MERCURY COUGAR
110,000 MILES • 4 CYL • FWD • MANUAL
JHILL62
Just replaced the lower a arms on both sides and took the battery out to do so. Started down the road to go to work and gauges went dead and engine stopped and will not even make an engage sound, but everything else seems to work in the dash electrical wise. Replaced the pos and neg battery cable ends all connections there are tight!!
May 17, 2009 at 5:11 PM
Probable causes:
Could be starter, starter relay, clutch interlock switch and ignition switch
May 17, 2009 at 5:55 PM
