2002 Mercury Cougar Code 401
130,000 MILES • 6 CYL • FWD • AUTOMATIC
NOSC
  • 11 POSTS
I have had the mighty cougar for a bit over a year now , shortly after buying it the CEL came on code 401. I was told it was the back pressure sensor so I replaced it.This is 11/07.Jan of 08 the light came back on , 401 again replaced it yet again.Thats how it started , every two months I was back at Auto Zone / Advanced Auto getting another sensor.This has happened ever since. Two months ago when the light came back on yet again with the 401 code I decided to try and find out why. I have had the car checked for carbon was told there was very little in it , I had it cleaned anyway. I then replaced the EGR Valve and the Back pressure senor light was off for maybe a month .I then added a can of Seafoam Motor tune up to the oil and gas .The car seems to be running better as well as idling better , I have more power than before , but I also have the 401 code again. Just today I replaced the O2 sensors on the engine the cat isnt stopped / blocked .The car is carbon free but I still get the 401 code. The EGR Valve and the latest BPS were both professionally installed in december of 08. I guess I am wanting to know what could possibly be throwing this code still? Am I overlooking something?
Also the car is still getting decent MPG like 20 in town.
Feb 24, 2009 at 9:43 AM
NOSC
  • 11 POSTS
I discovered what the problem was and the cougar now is running way better than it ever has. I just want to say dont fall for the DPFE/ EGR bit .
IF your MPG have not totally bottomed out it's not the DPFE/ back pressure sensor . The chance of a EGR going out are slim .
IF you are getting code P0401 thats egr insuffcient flow and means exactly thats, it's a insuffcient flow.
Meaning pull the throttle body off and clean it . These garages are making a killing off replacing parts that dont need to be replaced < dpfe >
Sooo save yourself some cash and ALOT of stress get the throttle body cleaned right off and a can of Seafoam wouldnt hurt either.
Mar 6, 2009 at 3:52 PM
