2002 Mercury Cougar
2002 MERCURY COUGAR
RLHOPPER
Electrical problem
2002 Mercury Cougar 6 cyl Two Wheel Drive Automatic
code p0352 ignition coil a i replaced coil plugs and wire still no fire out of those two wires also this just happened in the rain
Jan 28, 2010 at 1:38 PM
BMRFIXIT
  • 19,053 POSTS
Possible causes :
Ignition Coil Pack(s)
Ignition Coil Wiring Harness
IGN START/RUN Circuit To Coil Pack(s)
Powertrain Control Module (PCM)
if coil was replace next step should be is to check wiring harness
Jan 31, 2010 at 12:22 AM
