2002 Mercury Cougar Drum to Disc Brakes Fix
DWIKSTROM
I have a 2002 Mercury Cougar V6 2.5L 70,000 miles that has rear drum brakes. I want to change these to disc brakes. What do I need to change to accomplish this
Feb 17, 2007 at 4:56 AM
MERLIN2021
  • 17,250 POSTS
First you need to see if the mount will be the same on the axle, then you'll need 2 brake hoses, Master cylinder, combination valve, 2 steel lines, new parking brake cables, and oh yeah if you have anti-lock brakes,
Forget it!
Mar 4, 2007 at 8:22 PM
ROBERTSHOKZ
Many people freak out about rear discs and no abs, but it sounds not as if the abs goes off whenever you brake. Not to mention the higher tier 2002 cougars had rear discs std. But abs was only optional with the auto transmission. So I would say go for it, but I would recommend you use the stock disc brake components (not an aftermarket kit) otherwise the braking power will shift too much to the rear.
Feb 26, 2015 at 2:23 PM
Suggested Repair
Confirm the axle mounts match a disc setup, then plan on two brake hoses, a master cylinder, combination valve, two steel lines, and new parking brake cables. Do not attempt the conversion if the car has ABS. Prefer factory disc components from a disc-equipped Cougar rather than an aftermarket kit so rear brake bias does not increase too much.
Conversation Summary
The owner of a 2002 Mercury Cougar V6 with rear drums wants to convert them to disc brakes. The expert says to verify the axle mounts, replace the hoses, master cylinder, combination valve, steel lines, and parking brake cables, and abandon the idea if the car has ABS. Another reply notes that some 2002 Cougars had rear discs and recommends using stock disc parts rather than an aftermarket kit.
