2001 Mercury Cougar
2001 MERCURY COUGAR
MONE1725
Transmission problem
2001 Mercury Cougar 6 cyl Automatic
how do you add transmission fluid? i read online threw the dip stick is this true, help??
Oct 22, 2008 at 12:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, that is correct. Pour the fluid into the dipstick hole if the level is low. Use a long, thin funnel and add fluid making sure to check the fluid level each time you add 1/4 quart to avoid overfilling.
Oct 25, 2008 at 5:53 PM
