2000 Mercury Cougar transmission question
EKLINE51
To Whom It May Concern:
I am working on a 2000 Mercury Cougar. Three transmission shops advised me that the transmission problem is internal..., and said that the car's transmission could be rebuilt, replaced with a remanufactured transmission, or replaced with a transmission from an auto salvage yard. The owner of the car has opted to go with the third choice.
I obtained one from an auto salvage yard..., and my question is..., "can this specific transmission be dropped by itself, or do I need to pull the engine/transmission out of the car & seperate the two after they are out of the car?"
We are looking at a 2000 Mercury Cougar..., a 2.5L 155CID SFI DOHC VIN-L Duratec V6 engine..., and a 4-speed CD4E automatic transmission..., with 131,000 miles.
I'm a do-it-yourself person, with positively no hands-on experience on that year/make/model..., and I would appreciate it if anyone could answer the question mentioned above. I exhausted my resources for an EXACT Chilton or Haynes manual (I found some with years that were close), but came up empty-handed. I found a Haynes manual that guides you through rebuilding the transmission, once it's out..., but I'm looking for solid advice in removing/installing the transmission, and do it RIGHT, the first time.
Thank you, in advice, for any helpful advice.
Best regards,
Rick Kline
Feb 24, 2007 at 10:26 AM
CHEVY22
  • 1,375 POSTS
you can do this job without removing the engine but you will need a lift and alot of time if you havent done one before ,
the cd4e really wasnt a good transmission at all , i would try and talk the owner out of a used unit and go reman , believe me you wont want to pull that unit twice and if you need detailed info it will take alot of time to write it up the right way
thsnks jim
SOME FEEDBACK FOR THE EFFORT WOULD BE APPRECIATED WE ALL DONATE OUR TIME HELPING YOU
Feb 24, 2007 at 11:09 AM
