2000 Mercury Cougar idle
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAMES79NEFF
when i start the car the rpm jump to 2000 then fall to about 900 rpm the n engine starts shaking while idle jumps then dies restart car happens agin. unplug maf sensor engine smoothes out. replace maf sensor w/new one same problem. unplug egr valve vacum smoothes out . what could this be
Feb 26, 2009 at 8:01 AM
GREYHEN
[quote:15327c268c="james79neff"]Engine Performance problem
2000 Mercury Cougar 6 cyl Two Wheel Drive Automatic 100000 miles
when i start the car the rpm jump to 2000 then fall to about 900 rpm the n engine starts shaking while idle jumps then dies restart car happens agin. unplug maf sensor engine smoothes out. replace maf sensor w/new one same problem. unplug egr valve vacum smoothes out . what could this be[/quote:15327c268c]
does the check engine light come on?
Mar 3, 2009 at 9:41 AM
F4I_GUY
  • 3,302 POSTS
It sounds like an Idle Air Control Valve (IACV) issue. I would try servicing it first and see what happens.
Mar 3, 2009 at 9:55 AM
GREYHEN
The Exact same thing was happening to my car.
the problem with this type of issue is that there is a lot of intereaction between the functions of alot of the sensors. In effect a failure of one item can look like it is caused by another, I disconnected my EGR valve and plugged the line at the hose. I also tapped on the valve to try and get it to return to the relaxed position. the car ran fine until I plugged the EGR valve back in. Replaced Valve and car has ran fine for 2 weeks (knock on wood).. The CHECK ENGINE LIGHT would not come on right away. I got two codes P0171 and P0174. which are LEAN BANK 1 and LEAN BANK 2
Mar 6, 2009 at 5:22 AM
