1999 Mercury Cougar Sudden Loss Of Acceleration
1999 MERCURY COUGAR
58,000 MILES • 6 CYL • 2WD • AUTOMATIC
JUSIN001
Hi There.
Problem as Follows:
The engine starts fine... i drive down the road, maybe 5 miles, maybe 25 miles and then i have a loss in acceleration which lasts throughout all the gears (automatic) until i turn the ignition off and on again.
there is no particulat time of day this occurs nor temperature that seems to be making this problem occur.
i spoke with a garage and they said the obvious MAS replacament, but also they said it may be the gearbox causing a problem and between £1500 & 3000 to fix??
The computer shows no fault codes
what do you fine people think about this problem... thanks in advance..
Justin
Sep 14, 2008 at 10:17 PM
Could be the MAF sensor also might want to check on the throttle position sensor/output shaft sensor-or the transmission itself.
Sep 14, 2008 at 11:17 PM
JUSIN001
Thanks for Reply...
Do you feel that the automatic gearbox could be at fault?
Sep 15, 2008 at 12:26 AM
Could be if the band and clutches/valve body are no good its hard to say the transmission needs to be pressure tested
Sep 15, 2008 at 6:59 AM
