Hi There.
Problem as Follows:
The engine starts fine... i drive down the road, maybe 5 miles, maybe 25 miles and then i have a loss in acceleration which lasts throughout all the gears (automatic) until i turn the ignition off and on again.
there is no particulat time of day this occurs nor temperature that seems to be making this problem occur.
i spoke with a garage and they said the obvious MAS replacament, but also they said it may be the gearbox causing a problem and between £1500 & 3000 to fix??
The computer shows no fault codes
what do you fine people think about this problem... thanks in advance..
Justin
Problem as Follows:
Justin
Sep 15, 2008 at 5:17 AM
