1999 Mercury Cougar shifter
TOMMY MINX
Transmission problem
1999 Mercury Cougar 6 cyl Front Wheel Drive Automatic
My friend has a 1999 cougar. The shift lever will not go to neutral or park. Happened suddenly.
Oct 23, 2009 at 6:22 AM
DOCFIXIT
  • 18,828 POSTS
So is it stuck in gear? mean shifter physicaly not move ? are you appling brake? if yes do brake lights work?
Oct 23, 2009 at 7:56 AM
TOMMY MINX
when I apply the brake the brake lights come on but the shifter will not go into neutral, reverse, or park.
The shifter does however move through Drive, 1,and2. Thanks
Oct 24, 2009 at 12:09 PM
DOCFIXIT
  • 18,828 POSTS
Think problem is with Transmission Range Sensor to confirm trans will need scanning. Will key come out of ignition?
Oct 26, 2009 at 2:24 AM
