1999 Mercury Cougar put stop leak fluid in gas tank instead
1999 MERCURY COUGAR
10,200 MILES • 6 CYL • FWD • AUTOMATIC
ROBITYLER
I was smelling oil from my car and stopped to put a container of "stop oil leak" into my car.
I think I made a big mistake. I put it in my car via the gas tank. I think I should have put it in my oil compartment.
At the same time as putting this in my car I put a container of carberator cleaner in also through gas tank.
Will the stop oil leak stuff ruin my car if I put it in the wrong compartment???
Feb 19, 2010 at 11:53 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Is the Gas Tank Full? If so you may only notice some smoking and it may run a little rough. The full tank should thin the Oil Stop Leak enough not to cause clogging of the fuel sock, filter or the injectors.
Feb 19, 2010 at 11:59 AM
ROBITYLER
I filled my car up with gasoline at the same time I put the stop leak in my car.
Feb 19, 2010 at 12:12 PM
ROBITYLER
You are awesome to have replied so quickly. It gives me comfort to know that I don't need a new engine or transmission!
Feb 19, 2010 at 12:14 PM
