1999 Mercury Cougar low coolant and occasional smoke from t
1999 MERCURY COUGAR
PARDEBOI
Engine Mechanical problem
1999 Mercury Cougar 6 cyl Front Wheel Drive Manual 126xxx miles
I have a 99 cougar. 126xxx every once in a while it emits white smoke from the exhaust and i noticed during a video i made it shoots out a lot of water http://www.youtube.com/watch?v=_eamSDloxNMi have to add coolant about once a week. the car runs fine but after long drives on the highway 60+mph it smells really hot. the temp guage says its running at a normal temperature though? any insight would be great.
Apr 14, 2010 at 10:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
wouldn't be surprised if you have a failed head gasket. easy test for this is to remove radiator cap **WHILE COOL** then start vehicle *MAKE SURE NOONE IS NEAR RADIATOR AREA**. rev engine up a bit, if coolant shoots up out of radiator opening then you have cracked head gasket or head.
Apr 14, 2010 at 1:20 PM
