Fuel pump relay
76,000 MILES • 6 CYL • FWD • MANUAL
AIRPLANE_MECHBOY
In the fuse box on a my car, which relay is the fuel pump relay? I do not have a layout of the fuses and relays. Thanks
Aug 14, 2010 at 11:20 AM
WRENCHTECH
  • 20,760 POSTS
Here is a guide to help you test the relay once you find it from the diagrams below:
Here is the fuse panel and relay locations.
Cheers
Aug 14, 2010 at 12:33 PM
JH5012
My car has a v6 manual. I am having some trouble with it running rough after I stop. I will be going at a good rate of speed and then come to a quick stop, and the car bogs down like it is going to shut off. During acceleration there is major hesitation, only sometimes though. I am just wondering if it is the fuel pump relay or if it is the fuel pump itself?
Jul 5, 2018 at 6:29 AM (Merged)
FIXITMR
  • 9,989 POSTS
I would say fuel pump would cause other symptoms at all speeds and times. So it is not likely suspect. You can run pressure test to check it. Some people hook up permanent gauges.
JH5012
Okay, well would there be anything else that would cause that problem?
FIXITMR
  • 9,989 POSTS
JH5012
Nothing at all. The only things I have done so far mechanically is replacing the alternator and put on a ram air intake.
