1999 Mercury Cougar fluid leak
104,000 MILES • 6 CYL • FWD • MANUAL
WRHSONWHEELS
I have a pretty good leak that has to do with my power steering, but I can't see any visible points of the leaking. I do see it pouring out from the right(passenger) tie-rod boot? It drains out pretty fast and I have filled the P/S reservoir and it has emptied out. P/S pump looks fine as does the lines. So tight in there it's hard to get a real good look without removing alot of stuff! Anybody have any experience with this sort of symptom? Thanks in advance!
Apr 23, 2009 at 8:03 AM
BMRFIXIT
  • 19,053 POSTS
Rack and Pinion seal failure
need to have new rack and pinion
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 23, 2009 at 11:22 PM
WRHSONWHEELS
Thanks for the answer and link! bill
Apr 24, 2009 at 3:27 PM
