the easiest way to replace the alternator
MHART20
what's the easiest way to replace the alternator in my 99 mercury cougar?? its on the bottom left hand side of the engine. I cant get to it from the top, bottom or side
Oct 6, 2008 at 6:55 AM
IMPALASS
  • 3,112 POSTS
https://images.2carpros.com/forum/automotive_pictures/248015_Alt_0_1.gif
1. Disconnect the battery ground cable. 2. Remove the accessory drive belt.
https://images.2carpros.com/forum/automotive_pictures/248015_Alt_1_1.gif
3. Separate the tie-rod end from the wheel knuckle using the special tool 211-001 (TOOL-3290-D). CAUTION: Protect the ball joint seal to prevent damage.
https://images.2carpros.com/forum/automotive_pictures/248015_Alt_2_1.gif
4. Disconnect the generator electrical connectors (generator shown removed for clarity).
https://images.2carpros.com/forum/automotive_pictures/248015_Alt_3_1.gif
5. Remove the generator rear support bracket bolt.
https://images.2carpros.com/forum/automotive_pictures/248015_Alt_4_1.gif
6. Remove the generator upper bolt.
https://images.2carpros.com/forum/automotive_pictures/248015_Alt_5_1.gif
7. Remove the generator lower bolt.
https://images.2carpros.com/forum/automotive_pictures/248015_Alt_6_1.gif
8. Remove the generator through the wheel opening.
https://images.2carpros.com/forum/automotive_pictures/248015_Alt_7_1.gif
https://images.2carpros.com/forum/automotive_pictures/248015_Alt_8_1.gif
https://images.2carpros.com/forum/automotive_pictures/248015_Alt_9_1.gif
https://images.2carpros.com/forum/automotive_pictures/248015_Alt_10_1.gif
https://images.2carpros.com/forum/automotive_pictures/248015_Alt_11_1.gif
INSTALLATION To install, reverse the removal procedure.
Apr 21, 2021 at 6:43 AM
