1997 Mercury Cougar MIL light on
JCHOQ
  • 1997 MERCURY COUGAR
Computer problem
1997 Mercury Cougar Two Wheel Drive Automatic 104000 miles
I used a scan tool and the following error codes show: Po161 with freeze frame data; P0155; P0141; P0136; P0135 and pending codes P0135; P0136: P0141; P0155; P0161 they refer to O2 Heater Circuit. Does this indicate the O2 sensors are defective or is their some other problem that is causing the DTC codes?
The O2S monitor is solid and the status indicates "complete".
Thursday, May 21st, 2009 AT 11:26 PM
RACEFAN966
  • 5,029 POSTS
According to what I can find you have a malfunction on the heated circuit of the O2 sensor. If all the voltages are good with the O2's thens what it is saying is that you need to replace them. Hope this helps. If you need any more just ask.
Friday, May 22nd, 2009 AT 10:20 AM
JCHOQ
"If all the voltages are good with the O2's". Can you clarify what you mean by the above quoted statement that was in the answer.
Friday, May 22nd, 2009 AT 1:49 PM
RACEFAN966
  • 5,029 POSTS
Ok sure have you checked the voltages at the O2 sensor with a digital multi meter? If not then I will look up the wiring diagram and such and walk you through that so we can determine that the O2 sensor or sensors are bad. Thanks
Saturday, May 23rd, 2009 AT 8:42 AM
JCHOQ
No, I have not tested the O2 sensors, some instructions would be helpful.
Saturday, May 23rd, 2009 AT 11:57 AM
RACEFAN966
  • 5,029 POSTS
Ok now there are 4 sensors on you car and you will need to check them to see if the heated wire is getting power. Sensor 1 on the right side exhaust manifold check the red wire with the white stripe. Sensor 2 left side exhaust manifold check the yellow wire with the light blue stripe. Sensor 3 is at the rear of the engine in the exhaust pipe check the white wire with the black stripe. Sensor 4 also in the rear of exhaust pipe check the check the tan wire with the yellow stripe. Now you will need to use a paper clip to back probe the connector at each o2 sensor one at a time and then start the engine to see if the wire has power. If this checks out ok then we will look to the reference wires next. Let me know what you find and how much voltage is there.
Monday, May 25th, 2009 AT 10:04 AM
